2020 Palisade Infotainment Head Unit Replacement
Dirk
Does anyone know the difference between the Standard Class Gen5 Navigation Units type 1 and typ2 other than the look of the interface.
My Palisade head unit was replaced under warranty with a type 2 unit instead of a type 1. I asking to see if there is any reason to ask them to put in a type 1
Also any other information would be helpful. Thank you
What trim palisade do you have?
is it the 8" or 10" screen?
If it works right keep what they installed
How do you know it is a type 2 they installed.
Not sure but sounds like it might be an update from the older head unit.
Not even sure which head unit is installed in Palisade to begin with.
Maybe the difference in looks is because they updated you software to 14.10
which is different from the versions before.
D
Dirk
D
Dirk
Thread Starter #4
Hi Gene,
2020 Palisade Limited
Works fine, just a different GUI from what I can tell.
It is the 10" version and I know it is type 2 because of the description in the web manual. It is the split 2 screen rather then the tri screen Palisade usually has
It does look like it is a software upgrade but would have to go look at the numbers
Just wanted to know the differences between types 1 and 2
In the guide/manual for the navigation it lists type 1 and type 2 display. If that is what you are talking about,
It can be the same head unit, it is the software update that is the difference not the head unit.
Bet you had the 3 split screen before they replaced the head unit, type 1. now you have the 2 split screen
Right? That is the type 2.
It came with the new type two programing
I have a 2020 Limited that I purchased in July of 2019. I had 2 displays on the screen since day one showing the map and radio info. I was into the system the other day looking to change something and must have hit some button because when I returned by my home button I have a "3 split" screen, now showing map, weather, and radio displays. What happened is there a way to change it back. I can move the weather info. to where the radio is and then back but can't get rid of the weather info. to get back to a 2 screen display..???
Gene
Have you tried swiping up or down on the center section of the screen.
If you update the maps to 14.10 you will get a two screen display and no 3 screen
I didn't like it at first, the update, but now find some of the features nice
Only down fall is you have to log on as a guest to see destinations sent to car.
Two people can set up their stations and calls different, as driver1 and driver2
That is nice
Gene
Hi Gene,
Same head unit only has the new programming, type two, really different.
Did the swiping and got back to my 2 screen split.. Thanks.
